Time Before: 0.00205 seconds
Time After: 0.00256 seconds
Memory Before: 533.906 KB
Memory After: 559.023 KB
Time Before: 0.00263 seconds
Time After: 0.00302 seconds
Memory Before: 558.961 KB
Memory After: 559.969 KB
Time Before: 0.00323 seconds
Time After: 0.00335 seconds
Memory Before: 560.523 KB
Memory After: 561.047 KB
Time Before: 0.00418 seconds
Time After: 0.00630 seconds
Time Taken: 0.00212 seconds
Memory Before: 563.648 KB
Memory After: 564.570 KB
Time Before: 0.00344 seconds
Time After: 0.01101 seconds
Time Taken: 0.00757 seconds
Memory Before: 560.297 KB
Memory After: 1,641.297 KB
Memory Used: 1,081.000 KB
Time Before: 0.01286 seconds
Time After: 0.01331 seconds
Memory Before: 2,136.141 KB
Memory After: 2,136.758 KB
Time Before: 0.01609 seconds
Time After: 0.01782 seconds
Time Taken: 0.00173 seconds
Memory Before: 2,148.320 KB
Memory After: 2,148.180 KB
Time Before: 0.01223 seconds
Time After: 0.01804 seconds
Time Taken: 0.00581 seconds
Memory Before: 2,128.320 KB
Memory After: 2,261.203 KB
Time Before: 0.02487 seconds
Time After: 0.02502 seconds
Memory Before: 2,814.781 KB
Memory After: 2,815.297 KB
Time Before: 0.02792 seconds
Time After: 0.02911 seconds
Memory Before: 2,903.117 KB
Memory After: 2,903.711 KB
End call of global.php: 0.031536102294922
Time Before: 0.03276 seconds
Time After: 0.03289 seconds
Memory Before: 3,539.836 KB
Memory After: 3,540.266 KB
Time Before: 0.03563 seconds
Time After: 0.03720 seconds
Time Taken: 0.00157 seconds
Memory Before: 3,821.367 KB
Memory After: 3,823.055 KB
SET lastactivity = 1789029254, location = '/forums/private.php?do=newpm&explain=1&u=21296'
Time Before: 0.05116 seconds
Time After: 0.05156 seconds
Memory Before: 4,295.203 KB
Memory After: 4,295.430 KB
Page generated in 0.050246000289917 seconds with 9 queries, spending 0.0082354545593262 doing MySQL queries and 0.042010545730591 doing PHP things.
