Time Before: 0.01816 seconds
Time After: 0.02386 seconds
Time Taken: 0.00569 seconds
Time Before: 0.02397 seconds
Time After: 0.02438 seconds
Time Before: 0.02470 seconds
Time After: 0.02483 seconds
Time Before: 0.02575 seconds
Time After: 0.02895 seconds
Time Taken: 0.00320 seconds
Time Before: 0.02491 seconds
Time After: 0.03444 seconds
Time Taken: 0.00953 seconds
Time Before: 0.04027 seconds
Time After: 0.04067 seconds
Time Before: 0.04383 seconds
Time After: 0.04507 seconds
Time Before: 0.03960 seconds
Time After: 0.04527 seconds
Time Taken: 0.00567 seconds
Time Before: 0.07144 seconds
Time After: 0.07158 seconds
Time Before: 0.09518 seconds
Time After: 0.09674 seconds
Time Taken: 0.00156 seconds
Time Before: 0.10983 seconds
Time After: 0.10998 seconds
Time Before: 0.11251 seconds
Time After: 0.11398 seconds
UPDATE session SET lastactivity = 1783414873, location = '/forums/private.php?do=newpm&explain=1&u=21326', badlocation = 1 WHERE sessionhash = '785a5ccc852039ad054a2e3a39163c15'
Time Before: 0.13159 seconds
Time After: 0.13188 seconds
Memory Before: 4,289.406 KB
Memory After: 4,289.617 KB
