Time Before: 0.02194 seconds
Time After: 0.02886 seconds
Time Taken: 0.00691 seconds
Time Before: 0.02899 seconds
Time After: 0.02941 seconds
Time Before: 0.02966 seconds
Time After: 0.02977 seconds
Time Before: 0.03061 seconds
Time After: 0.03278 seconds
Time Taken: 0.00218 seconds
Time Before: 0.02985 seconds
Time After: 0.03666 seconds
Time Taken: 0.00681 seconds
Time Before: 0.04458 seconds
Time After: 0.04479 seconds
Time Before: 0.04614 seconds
Time After: 0.04730 seconds
Time Taken: 0.00117 seconds
Time Before: 0.04388 seconds
Time After: 0.04752 seconds
Time Taken: 0.00364 seconds
Time Before: 0.08734 seconds
Time After: 0.08747 seconds
Time Before: 0.50748 seconds
Time After: 0.50926 seconds
Time Taken: 0.00179 seconds
End call of global.php: 0.51160597801208
Time Before: 0.51860 seconds
Time After: 0.51881 seconds
Time Before: 0.52140 seconds
Time After: 0.52290 seconds
Time Taken: 0.00151 seconds
SET lastactivity = 1777119869, location = '/forums/private.php?do=newpm&explain=1&u=21439'
WHERE sessionhash = '7775e95b18bef93607bc556467059588'
Time Before: 0.54370 seconds
Time After: 0.54426 seconds
Time Taken: 0.00056 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
Page generated in 0.54232096672058 seconds with 9 queries, spending 0.0082600116729736 doing MySQL queries and 0.53406095504761 doing PHP things.
