Time Before: 0.01683 seconds
Time After: 0.02336 seconds
Time Taken: 0.00653 seconds
Time Before: 0.02348 seconds
Time After: 0.02405 seconds
Time Taken: 0.00057 seconds
Time Before: 0.02432 seconds
Time After: 0.02451 seconds
Time Before: 0.02540 seconds
Time After: 0.02823 seconds
Time Taken: 0.00283 seconds
Time Before: 0.02458 seconds
Time After: 0.03202 seconds
Time Taken: 0.00744 seconds
Time Before: 0.03844 seconds
Time After: 0.03884 seconds
Time Before: 0.04137 seconds
Time After: 0.04279 seconds
Time Before: 0.03762 seconds
Time After: 0.04300 seconds
Time Taken: 0.00538 seconds
Time Before: 0.07278 seconds
Time After: 0.07306 seconds
Time Before: 0.08491 seconds
Time After: 0.08633 seconds
Time Before: 0.09328 seconds
Time After: 0.09345 seconds
Time Before: 0.09544 seconds
Time After: 0.09689 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=21494' WHERE sessionhash = '5dcfbb55b5add1e7cfb509ae0e835a95'
Time Before: 0.11179 seconds
Time After: 0.11209 seconds
Memory Before: 4,287.734 KB
Memory After: 4,287.977 KB
