Time Before: 0.01662 seconds
Time After: 0.01912 seconds
Time Taken: 0.00250 seconds
Time Before: 0.01923 seconds
Time After: 0.01970 seconds
Time Before: 0.01993 seconds
Time After: 0.02006 seconds
Time Before: 0.02091 seconds
Time After: 0.02342 seconds
Time Taken: 0.00251 seconds
Time Before: 0.02015 seconds
Time After: 0.02761 seconds
Time Taken: 0.00746 seconds
Time Before: 0.03301 seconds
Time After: 0.03324 seconds
Time Before: 0.03655 seconds
Time After: 0.03774 seconds
Time Before: 0.03161 seconds
Time After: 0.03797 seconds
Time Taken: 0.00636 seconds
Time Before: 0.06232 seconds
Time After: 0.06258 seconds
Time Before: 0.07808 seconds
Time After: 0.07935 seconds
Time Before: 0.08807 seconds
Time After: 0.08825 seconds
Time Before: 0.09153 seconds
Time After: 0.09306 seconds
Time Taken: 0.00153 seconds
UPDATE session SET lastactivity = 1784932712, location = '/forums/private.php?do=newpm&explain=1&u=21509' WHERE sessionhash = 'b773d1d737f443efcc9fdfe9a9930185'
Time Before: 0.11304 seconds
Time After: 0.11332 seconds
Memory Before: 4,288.313 KB
Memory After: 4,288.539 KB
