Time Before: 0.01004 seconds
Time After: 0.01292 seconds
Time Taken: 0.00288 seconds
Time Before: 0.01303 seconds
Time After: 0.01379 seconds
Time Taken: 0.00077 seconds
Time Before: 0.01406 seconds
Time After: 0.01422 seconds
Time Before: 0.01518 seconds
Time After: 0.01739 seconds
Time Taken: 0.00221 seconds
Time Before: 0.01430 seconds
Time After: 0.02257 seconds
Time Taken: 0.00827 seconds
Time Before: 0.02599 seconds
Time After: 0.02638 seconds
Time Before: 0.02787 seconds
Time After: 0.02909 seconds
Time Before: 0.02533 seconds
Time After: 0.02933 seconds
Time Taken: 0.00400 seconds
Time Before: 0.05180 seconds
Time After: 0.05196 seconds
Time Before: 0.05984 seconds
Time After: 0.06264 seconds
Time Taken: 0.00280 seconds
End call of global.php: 0.065279006958008
Time Before: 0.06953 seconds
Time After: 0.06975 seconds
Time Before: 0.07234 seconds
Time After: 0.07384 seconds
SET lastactivity = 1776547208, location = '/forums/private.php?do=newpm&explain=1&u=21623', badlocation = 1
Time Before: 0.09309 seconds
Time After: 0.09345 seconds
Memory Before: 4,912.227 KB
Memory After: 4,912.438 KB
Page generated in 0.091937065124512 seconds with 9 queries, spending 0.009777307510376 doing MySQL queries and 0.082159757614136 doing PHP things.
