Time Before: 0.00165 seconds
Time After: 0.00219 seconds
Time Taken: 0.00054 seconds
Time Before: 0.00226 seconds
Time After: 0.00280 seconds
Time Before: 0.00309 seconds
Time After: 0.00327 seconds
Time Before: 0.00410 seconds
Time After: 0.00696 seconds
Time Taken: 0.00286 seconds
Time Before: 0.00335 seconds
Time After: 0.01120 seconds
Time Taken: 0.00786 seconds
Time Before: 0.01317 seconds
Time After: 0.01362 seconds
Time Before: 0.01627 seconds
Time After: 0.01763 seconds
Time Taken: 0.00136 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.01259 seconds
Time After: 0.01781 seconds
Time Taken: 0.00522 seconds
Memory After: 2,261.836 KB
Time Before: 0.02331 seconds
Time After: 0.02346 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.02535 seconds
Time After: 0.02665 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
End call of global.php: 0.028465986251831
Time Before: 0.02958 seconds
Time After: 0.02977 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.03173 seconds
Time After: 0.03321 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
SET lastactivity = 1789078881, location = '/forums/private.php?do=newpm&explain=1&u=2166'
Time Before: 0.04668 seconds
Time After: 0.04698 seconds
Memory Before: 4,287.586 KB
Memory After: 4,287.805 KB
Page generated in 0.045444011688232 seconds with 9 queries, spending 0.0088200569152832 doing MySQL queries and 0.036623954772949 doing PHP things.
