Time Before: 0.00168 seconds
Time After: 0.00232 seconds
Time Taken: 0.00063 seconds
Time Before: 0.00239 seconds
Time After: 0.00361 seconds
Time Before: 0.00398 seconds
Time After: 0.00425 seconds
Time Before: 0.00502 seconds
Time After: 0.00758 seconds
Time Taken: 0.00256 seconds
Time Before: 0.00430 seconds
Time After: 0.01291 seconds
Time Taken: 0.00861 seconds
Time Before: 0.01564 seconds
Time After: 0.01657 seconds
Time Taken: 0.00093 seconds
Time Before: 0.01911 seconds
Time After: 0.02034 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.01454 seconds
Time After: 0.02056 seconds
Time Taken: 0.00602 seconds
Memory After: 2,261.719 KB
Time Before: 0.02612 seconds
Time After: 0.02624 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.02829 seconds
Time After: 0.02952 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
End call of global.php: 0.031499147415161
Time Before: 0.03322 seconds
Time After: 0.03353 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.03677 seconds
Time After: 0.03828 seconds
Time Taken: 0.00151 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=21707', badlocation = 1
Time Before: 0.05789 seconds
Time After: 0.05861 seconds
Time Taken: 0.00072 seconds
Memory Before: 4,287.500 KB
Memory After: 4,287.727 KB
Page generated in 0.056416988372803 seconds with 9 queries, spending 0.010093927383423 doing MySQL queries and 0.04632306098938 doing PHP things.
