Time Before: 0.02478 seconds
Time After: 0.03167 seconds
Time Taken: 0.00689 seconds
Time Before: 0.03178 seconds
Time After: 0.03218 seconds
Time Before: 0.03252 seconds
Time After: 0.03271 seconds
Time Before: 0.03363 seconds
Time After: 0.03600 seconds
Time Taken: 0.00237 seconds
Time Before: 0.03278 seconds
Time After: 0.04086 seconds
Time Taken: 0.00808 seconds
Time Before: 0.04917 seconds
Time After: 0.04956 seconds
Time Before: 0.05211 seconds
Time After: 0.05346 seconds
Time Taken: 0.00135 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.04853 seconds
Time After: 0.05367 seconds
Time Taken: 0.00514 seconds
Memory After: 2,261.719 KB
Time Before: 0.08404 seconds
Time After: 0.08426 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.10293 seconds
Time After: 0.10428 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
Time Before: 0.11616 seconds
Time After: 0.11634 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.11912 seconds
Time After: 0.12096 seconds
Time Taken: 0.00184 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=21718', badlocation = 1 WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.14343 seconds
Time After: 0.14378 seconds
Memory Before: 4,287.500 KB
Memory After: 4,287.727 KB
