Time Before: 0.00140 seconds
Time After: 0.00190 seconds
Time Before: 0.00202 seconds
Time After: 0.00240 seconds
Time Before: 0.00264 seconds
Time After: 0.00286 seconds
Time Before: 0.00366 seconds
Time After: 0.00587 seconds
Time Taken: 0.00222 seconds
Time Before: 0.00294 seconds
Time After: 0.00923 seconds
Time Taken: 0.00629 seconds
Time Before: 0.01133 seconds
Time After: 0.01170 seconds
Time Before: 0.01435 seconds
Time After: 0.01555 seconds
Time Before: 0.01051 seconds
Time After: 0.01572 seconds
Time Taken: 0.00521 seconds
Time Before: 0.02081 seconds
Time After: 0.02096 seconds
Time Before: 0.02284 seconds
Time After: 0.02423 seconds
Time Taken: 0.00139 seconds
End call of global.php: 0.026767015457153
Time Before: 0.02822 seconds
Time After: 0.02839 seconds
Time Before: 0.03077 seconds
Time After: 0.03225 seconds
SET lastactivity = 1776799838, location = '/forums/private.php?do=newpm&explain=1&u=21819'
Time Before: 0.04739 seconds
Time After: 0.04775 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
Page generated in 0.046417951583862 seconds with 9 queries, spending 0.0079081058502197 doing MySQL queries and 0.038509845733643 doing PHP things.
