Time Before: 0.00158 seconds
Time After: 0.00217 seconds
Time Taken: 0.00059 seconds
Time Before: 0.00224 seconds
Time After: 0.00262 seconds
Time Before: 0.00291 seconds
Time After: 0.00321 seconds
Time Before: 0.00415 seconds
Time After: 0.00664 seconds
Time Taken: 0.00249 seconds
Time Before: 0.00328 seconds
Time After: 0.01188 seconds
Time Taken: 0.00860 seconds
Time Before: 0.01423 seconds
Time After: 0.01461 seconds
Time Before: 0.01718 seconds
Time After: 0.01848 seconds
Time Before: 0.01359 seconds
Time After: 0.01865 seconds
Time Taken: 0.00506 seconds
Time Before: 0.02425 seconds
Time After: 0.02437 seconds
Time Before: 0.02629 seconds
Time After: 0.02754 seconds
Time Before: 0.03070 seconds
Time After: 0.03088 seconds
Time Before: 0.03318 seconds
Time After: 0.03460 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=21826', badlocation = 1 WHERE sessionhash = '19bddeacfb649beeea65b05d036d70bd'
Time Before: 0.04734 seconds
Time After: 0.04763 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
