Time Before: 0.00146 seconds
Time After: 0.00215 seconds
Time Taken: 0.00069 seconds
Time Before: 0.00222 seconds
Time After: 0.00270 seconds
Time Before: 0.00299 seconds
Time After: 0.00314 seconds
Time Before: 0.00413 seconds
Time After: 0.00646 seconds
Time Taken: 0.00233 seconds
Time Before: 0.00322 seconds
Time After: 0.01210 seconds
Time Taken: 0.00888 seconds
Time Before: 0.01448 seconds
Time After: 0.01496 seconds
Time Before: 0.01823 seconds
Time After: 0.01942 seconds
Time Before: 0.01373 seconds
Time After: 0.01966 seconds
Time Taken: 0.00594 seconds
Time Before: 0.02521 seconds
Time After: 0.02536 seconds
Time Before: 0.02779 seconds
Time After: 0.02904 seconds
Time Before: 0.03339 seconds
Time After: 0.03354 seconds
Time Before: 0.03697 seconds
Time After: 0.03913 seconds
Time Taken: 0.00216 seconds
UPDATE session SET lastactivity = 1788897180, location = '/forums/private.php?do=newpm&explain=1&u=21837' WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.05429 seconds
Time After: 0.05461 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
