Time Before: 0.01469 seconds
Time After: 0.02063 seconds
Time Taken: 0.00594 seconds
Time Before: 0.02072 seconds
Time After: 0.02125 seconds
Time Taken: 0.00053 seconds
Time Before: 0.02152 seconds
Time After: 0.02164 seconds
Time Before: 0.02252 seconds
Time After: 0.02525 seconds
Time Taken: 0.00272 seconds
Time Before: 0.02170 seconds
Time After: 0.02976 seconds
Time Taken: 0.00806 seconds
Time Before: 0.03857 seconds
Time After: 0.03879 seconds
Time Before: 0.04139 seconds
Time After: 0.04267 seconds
Time Before: 0.03777 seconds
Time After: 0.04288 seconds
Time Taken: 0.00511 seconds
Time Before: 0.06297 seconds
Time After: 0.06312 seconds
Time Before: 0.07853 seconds
Time After: 0.07980 seconds
End call of global.php: 0.082401037216187
Time Before: 0.08780 seconds
Time After: 0.08795 seconds
Time Before: 0.09027 seconds
Time After: 0.09170 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=21880', badlocation = 1
Time Before: 0.10832 seconds
Time After: 0.10861 seconds
Memory Before: 4,288.836 KB
Memory After: 4,289.063 KB
Page generated in 0.10722899436951 seconds with 9 queries, spending 0.0081918239593506 doing MySQL queries and 0.099037170410156 doing PHP things.
