Time Before: 0.00249 seconds
Time After: 0.00293 seconds
Time Before: 0.00300 seconds
Time After: 0.00368 seconds
Time Taken: 0.00068 seconds
Time Before: 0.00399 seconds
Time After: 0.00416 seconds
Time Before: 0.00481 seconds
Time After: 0.00741 seconds
Time Taken: 0.00261 seconds
Time Before: 0.00421 seconds
Time After: 0.01081 seconds
Time Taken: 0.00661 seconds
Time Before: 0.01273 seconds
Time After: 0.01313 seconds
Time Before: 0.01563 seconds
Time After: 0.01692 seconds
Time Before: 0.01199 seconds
Time After: 0.01709 seconds
Time Taken: 0.00510 seconds
Time Before: 0.02221 seconds
Time After: 0.02237 seconds
Time Before: 0.02415 seconds
Time After: 0.02544 seconds
End call of global.php: 0.027186870574951
Time Before: 0.02843 seconds
Time After: 0.02863 seconds
Time Before: 0.03198 seconds
Time After: 0.03368 seconds
Time Taken: 0.00170 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=21888'
Time Before: 0.04838 seconds
Time After: 0.04870 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
Page generated in 0.047441005706787 seconds with 9 queries, spending 0.0088117122650146 doing MySQL queries and 0.038629293441772 doing PHP things.
