Time Before: 0.00198 seconds
Time After: 0.00255 seconds
Time Taken: 0.00058 seconds
Time Before: 0.00266 seconds
Time After: 0.00328 seconds
Time Taken: 0.00062 seconds
Time Before: 0.00351 seconds
Time After: 0.00363 seconds
Time Before: 0.00444 seconds
Time After: 0.00716 seconds
Time Taken: 0.00273 seconds
Time Before: 0.00368 seconds
Time After: 0.01056 seconds
Time Taken: 0.00688 seconds
Time Before: 0.01244 seconds
Time After: 0.01288 seconds
Time Before: 0.01594 seconds
Time After: 0.01711 seconds
Time Taken: 0.00117 seconds
Time Before: 0.01183 seconds
Time After: 0.01728 seconds
Time Taken: 0.00545 seconds
Time Before: 0.02222 seconds
Time After: 0.02234 seconds
Time Before: 0.02451 seconds
Time After: 0.02580 seconds
End call of global.php: 0.027424097061157
Time Before: 0.02894 seconds
Time After: 0.02915 seconds
Time Before: 0.03128 seconds
Time After: 0.03272 seconds
SET lastactivity = 1776667472, location = '/forums/private.php?do=newpm&explain=1&u=21926'
Time Before: 0.04804 seconds
Time After: 0.04838 seconds
Memory Before: 4,288.313 KB
Memory After: 4,288.539 KB
Page generated in 0.04678201675415 seconds with 9 queries, spending 0.0084676742553711 doing MySQL queries and 0.038314342498779 doing PHP things.
