Time Before: 0.00159 seconds
Time After: 0.00207 seconds
Time Before: 0.00214 seconds
Time After: 0.00266 seconds
Time Before: 0.00293 seconds
Time After: 0.00309 seconds
Time Before: 0.00397 seconds
Time After: 0.00667 seconds
Time Taken: 0.00270 seconds
Time Before: 0.00318 seconds
Time After: 0.01206 seconds
Time Taken: 0.00888 seconds
Time Before: 0.01426 seconds
Time After: 0.01460 seconds
Time Before: 0.01709 seconds
Time After: 0.01835 seconds
Time Before: 0.01368 seconds
Time After: 0.01858 seconds
Time Taken: 0.00490 seconds
Time Before: 0.02396 seconds
Time After: 0.02410 seconds
Time Before: 0.02662 seconds
Time After: 0.02822 seconds
Time Taken: 0.00160 seconds
Time Before: 0.03170 seconds
Time After: 0.03185 seconds
Time Before: 0.03502 seconds
Time After: 0.03650 seconds
UPDATE session SET lastactivity = 1788919922, location = '/forums/private.php?do=newpm&explain=1&u=21956', badlocation = 1 WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.05013 seconds
Time After: 0.05047 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
