Time Before: 0.01330 seconds
Time After: 0.01988 seconds
Time Taken: 0.00658 seconds
Time Before: 0.01996 seconds
Time After: 0.02035 seconds
Time Before: 0.02063 seconds
Time After: 0.02078 seconds
Time Before: 0.02150 seconds
Time After: 0.02406 seconds
Time Taken: 0.00256 seconds
Time Before: 0.02084 seconds
Time After: 0.02941 seconds
Time Taken: 0.00857 seconds
Time Before: 0.04325 seconds
Time After: 0.04382 seconds
Time Taken: 0.00057 seconds
Time Before: 0.04625 seconds
Time After: 0.04753 seconds
Time Before: 0.04253 seconds
Time After: 0.04774 seconds
Time Taken: 0.00522 seconds
Time Before: 0.06885 seconds
Time After: 0.06900 seconds
Time Before: 0.08882 seconds
Time After: 0.09010 seconds
Time Before: 0.09943 seconds
Time After: 0.09962 seconds
Time Before: 0.10187 seconds
Time After: 0.10330 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=22074', badlocation = 1 WHERE sessionhash = '3c1d29d6e59a1d652dc9473cfb455cd5'
Time Before: 0.12179 seconds
Time After: 0.12207 seconds
Memory Before: 4,288.016 KB
Memory After: 4,288.242 KB
