Time Before: 0.01596 seconds
Time After: 0.02397 seconds
Time Taken: 0.00801 seconds
Time Before: 0.02407 seconds
Time After: 0.02450 seconds
Time Before: 0.02477 seconds
Time After: 0.02496 seconds
Time Before: 0.02572 seconds
Time After: 0.02812 seconds
Time Taken: 0.00239 seconds
Time Before: 0.02502 seconds
Time After: 0.03256 seconds
Time Taken: 0.00754 seconds
Time Before: 0.03999 seconds
Time After: 0.04036 seconds
Time Before: 0.04285 seconds
Time After: 0.04408 seconds
Time Before: 0.03941 seconds
Time After: 0.04431 seconds
Time Taken: 0.00490 seconds
Time Before: 0.07455 seconds
Time After: 0.07468 seconds
Time Before: 0.35581 seconds
Time After: 0.35716 seconds
Time Taken: 0.00135 seconds
Time Before: 0.36702 seconds
Time After: 0.36719 seconds
Time Before: 0.36975 seconds
Time After: 0.37121 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=22098' WHERE sessionhash = 'b910b85238c3231bdc641e11d90490dd'
Time Before: 0.38824 seconds
Time After: 0.38848 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
