Time Before: 0.02777 seconds
Time After: 0.03433 seconds
Time Taken: 0.00656 seconds
Memory Before: 1,246.203 KB
Memory After: 1,273.008 KB
Time Before: 0.03443 seconds
Time After: 0.03488 seconds
Memory Before: 1,272.969 KB
Memory After: 1,273.945 KB
Time Before: 0.03516 seconds
Time After: 0.03537 seconds
Memory Before: 1,274.586 KB
Memory After: 1,275.109 KB
Time Before: 0.03615 seconds
Time After: 0.03836 seconds
Time Taken: 0.00221 seconds
Memory Before: 1,277.977 KB
Memory After: 1,278.898 KB
Time Before: 0.03542 seconds
Time After: 0.04318 seconds
Time Taken: 0.00776 seconds
Memory Before: 1,274.391 KB
Memory After: 2,355.609 KB
Memory Used: 1,081.219 KB
Time Before: 0.04880 seconds
Time After: 0.04923 seconds
Memory Before: 2,895.875 KB
Memory After: 2,896.492 KB
Time Before: 0.05190 seconds
Time After: 0.05333 seconds
Memory Before: 2,908.203 KB
Memory After: 2,908.063 KB
Time Before: 0.04797 seconds
Time After: 0.05356 seconds
Time Taken: 0.00558 seconds
Memory Before: 2,888.602 KB
Memory After: 3,021.133 KB
Memory Used: 132.531 KB
Time Before: 0.09532 seconds
Time After: 0.09543 seconds
Memory Before: 3,655.734 KB
Memory After: 3,656.250 KB
Time Before: 0.14913 seconds
Time After: 0.15042 seconds
Memory Before: 4,133.250 KB
Memory After: 4,133.844 KB
Time Before: 0.18385 seconds
Time After: 0.18402 seconds
Memory Before: 5,197.492 KB
Memory After: 5,325.836 KB
Time Before: 0.19248 seconds
Time After: 0.19393 seconds
Memory Before: 5,481.172 KB
Memory After: 5,610.773 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=22153', badlocation = 1 WHERE sessionhash = '84a1ba763b341c65c6e779f4d27b10fd'
Time Before: 0.22652 seconds
Time After: 0.23434 seconds
Time Taken: 0.00782 seconds
Memory Before: 5,998.492 KB
Memory After: 5,998.711 KB
