Time Before: 0.00172 seconds
Time After: 0.00252 seconds
Time Taken: 0.00080 seconds
Time Before: 0.00259 seconds
Time After: 0.00311 seconds
Time Before: 0.00335 seconds
Time After: 0.00348 seconds
Time Before: 0.00416 seconds
Time After: 0.00640 seconds
Time Taken: 0.00224 seconds
Time Before: 0.00354 seconds
Time After: 0.00974 seconds
Time Taken: 0.00620 seconds
Time Before: 0.01183 seconds
Time After: 0.01230 seconds
Time Before: 0.01479 seconds
Time After: 0.01602 seconds
Time Before: 0.01118 seconds
Time After: 0.01626 seconds
Time Taken: 0.00509 seconds
Time Before: 0.02277 seconds
Time After: 0.02301 seconds
Time Before: 0.02494 seconds
Time After: 0.02617 seconds
Time Before: 0.02921 seconds
Time After: 0.02949 seconds
Time Before: 0.03158 seconds
Time After: 0.03305 seconds
UPDATE session SET lastactivity = 1777066434, location = '/forums/private.php?do=newpm&explain=1&u=22168', badlocation = 1 WHERE sessionhash = '87651ca345a619a09949038b7f47c9ec'
Time Before: 0.04561 seconds
Time After: 0.04597 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
