Time Before: 0.02205 seconds
Time After: 0.02769 seconds
Time Taken: 0.00564 seconds
Time Before: 0.02779 seconds
Time After: 0.02883 seconds
Time Taken: 0.00104 seconds
Time Before: 0.02909 seconds
Time After: 0.02922 seconds
Time Before: 0.03001 seconds
Time After: 0.03256 seconds
Time Taken: 0.00255 seconds
Time Before: 0.02928 seconds
Time After: 0.03635 seconds
Time Taken: 0.00707 seconds
Time Before: 0.04490 seconds
Time After: 0.04526 seconds
Time Before: 0.04796 seconds
Time After: 0.04922 seconds
Time Before: 0.04422 seconds
Time After: 0.04940 seconds
Time Taken: 0.00518 seconds
Time Before: 0.08035 seconds
Time After: 0.08131 seconds
Time Taken: 0.00096 seconds
Time Before: 0.19608 seconds
Time After: 0.19733 seconds
End call of global.php: 0.20042300224304
Time Before: 0.20662 seconds
Time After: 0.20677 seconds
Time Before: 0.20948 seconds
Time After: 0.21091 seconds
SET lastactivity = 1783010696, location = '/forums/private.php?do=newpm&explain=1&u=22205', badlocation = 1
Time Before: 0.22715 seconds
Time After: 0.22748 seconds
Memory Before: 4,288.594 KB
Memory After: 4,288.805 KB
Page generated in 0.2261528968811 seconds with 9 queries, spending 0.0094602108001709 doing MySQL queries and 0.21669268608093 doing PHP things.
