Time Before: 0.01629 seconds
Time After: 0.02217 seconds
Time Taken: 0.00588 seconds
Time Before: 0.02230 seconds
Time After: 0.02275 seconds
Time Before: 0.02299 seconds
Time After: 0.02312 seconds
Time Before: 0.02450 seconds
Time After: 0.02792 seconds
Time Taken: 0.00342 seconds
Time Before: 0.02321 seconds
Time After: 0.03263 seconds
Time Taken: 0.00941 seconds
Time Before: 0.03992 seconds
Time After: 0.04037 seconds
Time Before: 0.04299 seconds
Time After: 0.04426 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.03925 seconds
Time After: 0.04451 seconds
Time Taken: 0.00526 seconds
Memory After: 2,261.719 KB
Time Before: 0.07000 seconds
Time After: 0.07017 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.16588 seconds
Time After: 0.16711 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
Time Before: 0.17465 seconds
Time After: 0.17483 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.17731 seconds
Time After: 0.17874 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=22220', badlocation = 1 WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.19675 seconds
Time After: 0.19722 seconds
Memory Before: 4,287.500 KB
Memory After: 4,287.727 KB
