Time Before: 0.02291 seconds
Time After: 0.02604 seconds
Time Taken: 0.00313 seconds
Time Before: 0.02612 seconds
Time After: 0.02647 seconds
Time Before: 0.02666 seconds
Time After: 0.02675 seconds
Time Taken: 0.00009 seconds
Time Before: 0.02741 seconds
Time After: 0.03032 seconds
Time Taken: 0.00292 seconds
Time Before: 0.02680 seconds
Time After: 0.03441 seconds
Time Taken: 0.00761 seconds
Time Before: 0.04693 seconds
Time After: 0.04746 seconds
Time Taken: 0.00053 seconds
Time Before: 0.04866 seconds
Time After: 0.05015 seconds
Time Before: 0.04633 seconds
Time After: 0.05039 seconds
Time Taken: 0.00406 seconds
Time Before: 0.08758 seconds
Time After: 0.08772 seconds
Time Before: 0.10409 seconds
Time After: 0.10535 seconds
Time Before: 0.11822 seconds
Time After: 0.11836 seconds
Time Before: 0.12116 seconds
Time After: 0.12259 seconds
UPDATE session SET lastactivity = 1776573632, location = '/forums/private.php?do=newpm&explain=1&u=22284' WHERE sessionhash = '0072f2714e5608fd7a8a8d7024a3e041'
Time Before: 0.14473 seconds
Time After: 0.14500 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
