Time Before: 0.00171 seconds
Time After: 0.00225 seconds
Time Taken: 0.00054 seconds
Time Before: 0.00233 seconds
Time After: 0.00360 seconds
Time Before: 0.00380 seconds
Time After: 0.00393 seconds
Time Before: 0.00469 seconds
Time After: 0.00746 seconds
Time Taken: 0.00277 seconds
Time Before: 0.00398 seconds
Time After: 0.01101 seconds
Time Taken: 0.00704 seconds
Time Before: 0.01297 seconds
Time After: 0.01340 seconds
Time Before: 0.01739 seconds
Time After: 0.01863 seconds
Time Before: 0.01224 seconds
Time After: 0.01891 seconds
Time Taken: 0.00667 seconds
Time Before: 0.02561 seconds
Time After: 0.02573 seconds
Time Before: 0.02790 seconds
Time After: 0.02914 seconds
End call of global.php: 0.031776189804077
Time Before: 0.03390 seconds
Time After: 0.03405 seconds
Time Before: 0.03730 seconds
Time After: 0.03875 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=22321', badlocation = 1
WHERE sessionhash = '05469e5b46550d3cbf9ccd27256b5c39'
Time Before: 0.05507 seconds
Time After: 0.05541 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
Page generated in 0.054126977920532 seconds with 9 queries, spending 0.0091514587402344 doing MySQL queries and 0.044975519180298 doing PHP things.
