Time Before: 0.01662 seconds
Time After: 0.02111 seconds
Time Taken: 0.00449 seconds
Time Before: 0.02121 seconds
Time After: 0.02168 seconds
Time Before: 0.02196 seconds
Time After: 0.02209 seconds
Time Before: 0.02289 seconds
Time After: 0.02565 seconds
Time Taken: 0.00276 seconds
Time Before: 0.02216 seconds
Time After: 0.02977 seconds
Time Taken: 0.00761 seconds
Time Before: 0.03956 seconds
Time After: 0.03992 seconds
Time Before: 0.04304 seconds
Time After: 0.04425 seconds
Time Before: 0.03887 seconds
Time After: 0.04449 seconds
Time Taken: 0.00563 seconds
Time Before: 0.09302 seconds
Time After: 0.09316 seconds
Time Before: 0.11203 seconds
Time After: 0.11347 seconds
Time Before: 0.12330 seconds
Time After: 0.12359 seconds
Time Before: 0.12652 seconds
Time After: 0.12801 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=22341' WHERE sessionhash = 'f9921609250f226198462d57df303337'
Time Before: 0.14750 seconds
Time After: 0.14785 seconds
Memory Before: 4,911.656 KB
Memory After: 4,911.898 KB
