Time Before: 0.00141 seconds
Time After: 0.00182 seconds
Time Before: 0.00189 seconds
Time After: 0.00241 seconds
Time Before: 0.00265 seconds
Time After: 0.00279 seconds
Time Before: 0.00346 seconds
Time After: 0.00626 seconds
Time Taken: 0.00280 seconds
Time Before: 0.00284 seconds
Time After: 0.00974 seconds
Time Taken: 0.00690 seconds
Time Before: 0.01244 seconds
Time After: 0.01288 seconds
Time Before: 0.01565 seconds
Time After: 0.01698 seconds
Time Taken: 0.00133 seconds
Time Before: 0.01164 seconds
Time After: 0.01722 seconds
Time Taken: 0.00558 seconds
Time Before: 0.02330 seconds
Time After: 0.02353 seconds
REPLACE INTO datastore
(title, data, unserialize)
VALUES
('loadcache', 'a:2:{s:7:\"loadavg\";s:6:\"17.32,\";s:9:\"lastcheck\";i:1785264032;}', 1)Time Before: 0.02936 seconds
Time After: 0.02981 seconds
Memory Before: 3,439.641 KB
Memory After: 3,439.891 KB
Memory Used: 0.250 KB
Time Before: 0.03226 seconds
Time After: 0.03353 seconds
Memory Before: 3,526.445 KB
Memory After: 3,527.039 KB
Time Before: 0.03701 seconds
Time After: 0.03720 seconds
Memory Before: 4,164.313 KB
Memory After: 4,164.742 KB
Time Before: 0.03942 seconds
Time After: 0.04082 seconds
Time Taken: 0.00139 seconds
Memory Before: 4,446.055 KB
Memory After: 4,447.742 KB
UPDATE session SET lastactivity = 1785264032, location = '/forums/private.php?do=newpm&explain=1&u=2235' WHERE sessionhash = '1bdac016e56aac80b5f324b5c0ae82e4'
Time Before: 0.05358 seconds
Time After: 0.05387 seconds
Memory Before: 4,919.734 KB
Memory After: 4,919.938 KB
Memory Used: 0.203 KB
