Time Before: 0.00144 seconds
Time After: 0.00197 seconds
Time Taken: 0.00053 seconds
Memory Before: 1,159.359 KB
Memory After: 1,184.477 KB
Time Before: 0.00204 seconds
Time After: 0.00242 seconds
Memory Before: 1,184.414 KB
Memory After: 1,185.422 KB
Time Before: 0.00261 seconds
Time After: 0.00271 seconds
Time Taken: 0.00010 seconds
Memory Before: 1,186.008 KB
Memory After: 1,186.531 KB
Time Before: 0.00338 seconds
Time After: 0.00571 seconds
Time Taken: 0.00234 seconds
Memory Before: 1,189.133 KB
Memory After: 1,190.055 KB
Time Before: 0.00276 seconds
Time After: 0.00970 seconds
Time Taken: 0.00694 seconds
Memory Before: 1,185.750 KB
Memory After: 2,266.766 KB
Time Before: 0.01275 seconds
Time After: 0.01312 seconds
Memory Before: 2,759.469 KB
Memory After: 2,760.086 KB
Time Before: 0.01521 seconds
Time After: 0.01645 seconds
Memory Before: 2,771.641 KB
Memory After: 2,771.500 KB
Time Before: 0.01205 seconds
Time After: 0.01663 seconds
Time Taken: 0.00458 seconds
Memory Before: 2,751.609 KB
Memory After: 2,884.531 KB
Time Before: 0.02598 seconds
Time After: 0.02615 seconds
Memory Before: 3,437.641 KB
Memory After: 3,438.156 KB
Time Before: 0.02828 seconds
Time After: 0.02947 seconds
Memory Before: 3,525.438 KB
Memory After: 3,526.031 KB
Time Before: 0.03279 seconds
Time After: 0.03295 seconds
Memory Before: 4,163.305 KB
Memory After: 4,163.734 KB
Time Before: 0.03480 seconds
Time After: 0.03620 seconds
Time Taken: 0.00139 seconds
Memory Before: 4,444.867 KB
Memory After: 4,446.555 KB
UPDATE session SET lastactivity = 1784718823, location = '/forums/private.php?do=newpm&explain=1&u=22393' WHERE sessionhash = 'b910b85238c3231bdc641e11d90490dd'
Time Before: 0.04972 seconds
Time After: 0.05009 seconds
Memory Before: 4,918.703 KB
Memory After: 4,918.930 KB
