Time Before: 0.01263 seconds
Time After: 0.01766 seconds
Time Taken: 0.00503 seconds
Time Before: 0.01776 seconds
Time After: 0.01818 seconds
Time Before: 0.01844 seconds
Time After: 0.01856 seconds
Time Before: 0.01942 seconds
Time After: 0.02156 seconds
Time Taken: 0.00214 seconds
Time Before: 0.01862 seconds
Time After: 0.02528 seconds
Time Taken: 0.00667 seconds
Time Before: 0.02967 seconds
Time After: 0.02991 seconds
Time Before: 0.03291 seconds
Time After: 0.03411 seconds
Time Before: 0.02886 seconds
Time After: 0.03438 seconds
Time Taken: 0.00552 seconds
Time Before: 0.05636 seconds
Time After: 0.05654 seconds
Time Before: 0.07137 seconds
Time After: 0.07265 seconds
Time Before: 0.08056 seconds
Time After: 0.08075 seconds
Time Before: 0.08407 seconds
Time After: 0.08566 seconds
Time Taken: 0.00159 seconds
UPDATE session SET lastactivity = 1783162276, location = '/forums/private.php?do=newpm&explain=1&u=22405', badlocation = 1 WHERE sessionhash = '7ca6ab718f0d2129a0db1a6bd7e3c55b'
Time Before: 0.10598 seconds
Time After: 0.10623 seconds
Memory Before: 4,289.406 KB
Memory After: 4,289.617 KB
