Time Before: 0.00196 seconds
Time After: 0.00296 seconds
Time Taken: 0.00100 seconds
Time Before: 0.00305 seconds
Time After: 0.00350 seconds
Time Before: 0.00396 seconds
Time After: 0.00441 seconds
Time Before: 0.00509 seconds
Time After: 0.00750 seconds
Time Taken: 0.00241 seconds
Time Before: 0.00449 seconds
Time After: 0.01098 seconds
Time Taken: 0.00649 seconds
Time Before: 0.01268 seconds
Time After: 0.01308 seconds
Time Before: 0.01553 seconds
Time After: 0.01834 seconds
Time Taken: 0.00281 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.01214 seconds
Time After: 0.01855 seconds
Time Taken: 0.00641 seconds
Memory After: 2,261.719 KB
Time Before: 0.02477 seconds
Time After: 0.02492 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.02696 seconds
Time After: 0.02828 seconds
Time Taken: 0.00132 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
End call of global.php: 0.029893159866333
Time Before: 0.03129 seconds
Time After: 0.03143 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.03341 seconds
Time After: 0.03485 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=22479'
Time Before: 0.04726 seconds
Time After: 0.04758 seconds
Memory Before: 4,287.219 KB
Memory After: 4,287.461 KB
Page generated in 0.04633903503418 seconds with 9 queries, spending 0.0098941326141357 doing MySQL queries and 0.036444902420044 doing PHP things.
