Time Before: 0.00416 seconds
Time After: 0.00603 seconds
Time Taken: 0.00186 seconds
Time Before: 0.00612 seconds
Time After: 0.00663 seconds
Time Before: 0.00696 seconds
Time After: 0.00711 seconds
Time Before: 0.00779 seconds
Time After: 0.01009 seconds
Time Taken: 0.00231 seconds
Time Before: 0.00716 seconds
Time After: 0.01346 seconds
Time Taken: 0.00630 seconds
Time Before: 0.01612 seconds
Time After: 0.01629 seconds
Time Before: 0.01870 seconds
Time After: 0.01993 seconds
Time Before: 0.01551 seconds
Time After: 0.02010 seconds
Time Taken: 0.00459 seconds
Time Before: 0.02610 seconds
Time After: 0.02621 seconds
Time Before: 0.02904 seconds
Time After: 0.03026 seconds
End call of global.php: 0.031980991363525
Time Before: 0.03383 seconds
Time After: 0.03396 seconds
Time Before: 0.03617 seconds
Time After: 0.03864 seconds
Time Taken: 0.00246 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=22512', badlocation = 1
Time Before: 0.05580 seconds
Time After: 0.05606 seconds
Memory Before: 4,288.016 KB
Memory After: 4,288.242 KB
Page generated in 0.054838895797729 seconds with 9 queries, spending 0.0085506439208984 doing MySQL queries and 0.046288251876831 doing PHP things.
