Time Before: 0.00875 seconds
Time After: 0.01185 seconds
Time Taken: 0.00310 seconds
Time Before: 0.01194 seconds
Time After: 0.01238 seconds
Time Before: 0.01262 seconds
Time After: 0.01278 seconds
Time Before: 0.01353 seconds
Time After: 0.01545 seconds
Time Taken: 0.00192 seconds
Time Before: 0.01286 seconds
Time After: 0.02017 seconds
Time Taken: 0.00730 seconds
Time Before: 0.02517 seconds
Time After: 0.02561 seconds
Time Before: 0.02812 seconds
Time After: 0.02931 seconds
Time Before: 0.02452 seconds
Time After: 0.02955 seconds
Time Taken: 0.00503 seconds
Time Before: 0.05040 seconds
Time After: 0.05060 seconds
Time Before: 0.06192 seconds
Time After: 0.06318 seconds
End call of global.php: 0.065454006195068
Time Before: 0.06881 seconds
Time After: 0.06898 seconds
Time Before: 0.07145 seconds
Time After: 0.07290 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=22525'
Time Before: 0.08995 seconds
Time After: 0.09016 seconds
Memory Before: 4,287.734 KB
Memory After: 4,287.977 KB
Page generated in 0.088926076889038 seconds with 9 queries, spending 0.0074336528778076 doing MySQL queries and 0.08149242401123 doing PHP things.
