Time Before: 0.00577 seconds
Time After: 0.00705 seconds
Time Before: 0.00717 seconds
Time After: 0.00757 seconds
Time Before: 0.00785 seconds
Time After: 0.00804 seconds
Time Before: 0.00911 seconds
Time After: 0.01156 seconds
Time Taken: 0.00245 seconds
Time Before: 0.00813 seconds
Time After: 0.01723 seconds
Time Taken: 0.00910 seconds
Time Before: 0.02010 seconds
Time After: 0.02060 seconds
Time Before: 0.02318 seconds
Time After: 0.02440 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.01926 seconds
Time After: 0.02463 seconds
Time Taken: 0.00537 seconds
Memory After: 2,261.836 KB
Time Before: 0.03834 seconds
Time After: 0.03851 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.04443 seconds
Time After: 0.04565 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
Time Before: 0.05169 seconds
Time After: 0.05185 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.05435 seconds
Time After: 0.05621 seconds
Time Taken: 0.00186 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
UPDATE session SET lastactivity = 1788884179, location = '/forums/private.php?do=newpm&explain=1&u=22546' WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.07205 seconds
Time After: 0.07244 seconds
Memory Before: 4,287.578 KB
Memory After: 4,287.805 KB
