Time Before: 0.00140 seconds
Time After: 0.00193 seconds
Time Taken: 0.00054 seconds
Time Before: 0.00200 seconds
Time After: 0.00260 seconds
Time Taken: 0.00061 seconds
Time Before: 0.00290 seconds
Time After: 0.00306 seconds
Time Before: 0.00372 seconds
Time After: 0.00656 seconds
Time Taken: 0.00283 seconds
Time Before: 0.00311 seconds
Time After: 0.00991 seconds
Time Taken: 0.00680 seconds
Time Before: 0.01167 seconds
Time After: 0.01206 seconds
Time Before: 0.01336 seconds
Time After: 0.01454 seconds
Time Taken: 0.00118 seconds
Time Before: 0.01112 seconds
Time After: 0.01471 seconds
Time Taken: 0.00359 seconds
Time Before: 0.02012 seconds
Time After: 0.02030 seconds
Time Before: 0.02224 seconds
Time After: 0.02353 seconds
Time Before: 0.02639 seconds
Time After: 0.02657 seconds
Time Before: 0.02855 seconds
Time After: 0.03000 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=22612', badlocation = 1 WHERE sessionhash = 'dd14cf6af34df6bab38ac9fb3783395f'
Time Before: 0.04252 seconds
Time After: 0.04289 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
