Time Before: 0.00137 seconds
Time After: 0.00187 seconds
Time Before: 0.00194 seconds
Time After: 0.00245 seconds
Time Before: 0.00271 seconds
Time After: 0.00284 seconds
Time Before: 0.00371 seconds
Time After: 0.00595 seconds
Time Taken: 0.00223 seconds
Time Before: 0.00292 seconds
Time After: 0.00942 seconds
Time Taken: 0.00650 seconds
Time Before: 0.01137 seconds
Time After: 0.01180 seconds
Time Before: 0.01498 seconds
Time After: 0.01618 seconds
Time Before: 0.01065 seconds
Time After: 0.01645 seconds
Time Taken: 0.00580 seconds
Time Before: 0.02298 seconds
Time After: 0.02312 seconds
Time Before: 0.02567 seconds
Time After: 0.02702 seconds
Time Taken: 0.00135 seconds
End call of global.php: 0.028920888900757
Time Before: 0.03018 seconds
Time After: 0.03036 seconds
Time Before: 0.03242 seconds
Time After: 0.03381 seconds
Time Taken: 0.00139 seconds
SET lastactivity = 1789072725, location = '/forums/private.php?do=newpm&explain=1&u=22676', badlocation = 1
Time Before: 0.04784 seconds
Time After: 0.04811 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
Page generated in 0.046917915344238 seconds with 9 queries, spending 0.0078279972076416 doing MySQL queries and 0.039089918136597 doing PHP things.
