Time Before: 0.01128 seconds
Time After: 0.01773 seconds
Time Taken: 0.00645 seconds
Time Before: 0.01784 seconds
Time After: 0.01830 seconds
Time Before: 0.01854 seconds
Time After: 0.01869 seconds
Time Before: 0.01960 seconds
Time After: 0.02208 seconds
Time Taken: 0.00248 seconds
Time Before: 0.01875 seconds
Time After: 0.02559 seconds
Time Taken: 0.00684 seconds
Time Before: 0.02987 seconds
Time After: 0.03035 seconds
Time Before: 0.03334 seconds
Time After: 0.03481 seconds
Time Before: 0.02928 seconds
Time After: 0.03503 seconds
Time Taken: 0.00576 seconds
Time Before: 0.05416 seconds
Time After: 0.05438 seconds
Time Before: 0.06533 seconds
Time After: 0.06653 seconds
Time Before: 0.07259 seconds
Time After: 0.07273 seconds
Time Before: 0.07481 seconds
Time After: 0.07628 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=22804' WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.09416 seconds
Time After: 0.09539 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
