Time Before: 0.01514 seconds
Time After: 0.01892 seconds
Time Taken: 0.00379 seconds
Time Before: 0.01904 seconds
Time After: 0.01959 seconds
Time Taken: 0.00055 seconds
Time Before: 0.01990 seconds
Time After: 0.02006 seconds
Time Before: 0.02081 seconds
Time After: 0.02313 seconds
Time Taken: 0.00232 seconds
Time Before: 0.02014 seconds
Time After: 0.02736 seconds
Time Taken: 0.00722 seconds
Time Before: 0.03177 seconds
Time After: 0.03216 seconds
Time Before: 0.03467 seconds
Time After: 0.03586 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.03107 seconds
Time After: 0.03605 seconds
Time Taken: 0.00498 seconds
Memory After: 2,261.719 KB
Time Before: 0.06615 seconds
Time After: 0.06631 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.08177 seconds
Time After: 0.08305 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
Time Before: 0.09150 seconds
Time After: 0.09171 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.09424 seconds
Time After: 0.09579 seconds
Time Taken: 0.00155 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=22921', badlocation = 1 WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.11391 seconds
Time After: 0.11430 seconds
Memory Before: 4,287.500 KB
Memory After: 4,287.727 KB
