Time Before: 0.00216 seconds
Time After: 0.00269 seconds
Time Before: 0.00281 seconds
Time After: 0.00322 seconds
Time Before: 0.00345 seconds
Time After: 0.00358 seconds
Time Before: 0.00444 seconds
Time After: 0.00717 seconds
Time Taken: 0.00273 seconds
Time Before: 0.00366 seconds
Time After: 0.01162 seconds
Time Taken: 0.00796 seconds
Time Before: 0.01396 seconds
Time After: 0.01432 seconds
Time Before: 0.01720 seconds
Time After: 0.01839 seconds
Time Before: 0.01331 seconds
Time After: 0.01859 seconds
Time Taken: 0.00528 seconds
Time Before: 0.02382 seconds
Time After: 0.02396 seconds
Time Before: 0.02642 seconds
Time After: 0.02764 seconds
Time Before: 0.03069 seconds
Time After: 0.03082 seconds
Time Before: 0.03277 seconds
Time After: 0.03419 seconds
UPDATE session SET lastactivity = 1785386325, location = '/forums/private.php?do=newpm&explain=1&u=23004' WHERE sessionhash = '1b43d45bbaaa70ba8be59b846adc9cfa'
Time Before: 0.04704 seconds
Time After: 0.04733 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
