Time Before: 0.00165 seconds
Time After: 0.00226 seconds
Time Taken: 0.00061 seconds
Time Before: 0.00233 seconds
Time After: 0.00289 seconds
Time Taken: 0.00057 seconds
Time Before: 0.00312 seconds
Time After: 0.00324 seconds
Time Before: 0.00412 seconds
Time After: 0.00689 seconds
Time Taken: 0.00277 seconds
Time Before: 0.00329 seconds
Time After: 0.01142 seconds
Time Taken: 0.00813 seconds
Time Before: 0.01347 seconds
Time After: 0.01397 seconds
Time Before: 0.01550 seconds
Time After: 0.01674 seconds
Time Before: 0.01270 seconds
Time After: 0.01694 seconds
Time Taken: 0.00424 seconds
Time Before: 0.02222 seconds
Time After: 0.02236 seconds
Time Before: 0.02476 seconds
Time After: 0.02607 seconds
Time Taken: 0.00131 seconds
Time Before: 0.03058 seconds
Time After: 0.03080 seconds
Time Before: 0.03326 seconds
Time After: 0.03466 seconds
Time Taken: 0.00140 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=23078' WHERE sessionhash = '7f12e449499bf5aa31d8d04cb08a0450'
Time Before: 0.04730 seconds
Time After: 0.04781 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
