Time Before: 0.00139 seconds
Time After: 0.00190 seconds
Time Before: 0.00197 seconds
Time After: 0.00249 seconds
Time Before: 0.00274 seconds
Time After: 0.00289 seconds
Time Before: 0.00375 seconds
Time After: 0.00647 seconds
Time Taken: 0.00272 seconds
Time Before: 0.00296 seconds
Time After: 0.01119 seconds
Time Taken: 0.00823 seconds
Time Before: 0.01331 seconds
Time After: 0.01378 seconds
Time Before: 0.01628 seconds
Time After: 0.01755 seconds
Time Before: 0.01267 seconds
Time After: 0.01778 seconds
Time Taken: 0.00511 seconds
Time Before: 0.02286 seconds
Time After: 0.02305 seconds
Time Before: 0.02531 seconds
Time After: 0.02657 seconds
End call of global.php: 0.029040098190308
Time Before: 0.03043 seconds
Time After: 0.03064 seconds
Time Before: 0.03287 seconds
Time After: 0.03434 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=23111'
Time Before: 0.04688 seconds
Time After: 0.04726 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
Page generated in 0.045957088470459 seconds with 9 queries, spending 0.0086009502410889 doing MySQL queries and 0.03735613822937 doing PHP things.
