Time Before: 0.01831 seconds
Time After: 0.02389 seconds
Time Taken: 0.00558 seconds
Memory Before: 1,246.203 KB
Memory After: 1,273.008 KB
Time Before: 0.02401 seconds
Time After: 0.02442 seconds
Memory Before: 1,272.969 KB
Memory After: 1,273.945 KB
Time Before: 0.02469 seconds
Time After: 0.02482 seconds
Memory Before: 1,274.586 KB
Memory After: 1,275.109 KB
Time Before: 0.02562 seconds
Time After: 0.02798 seconds
Time Taken: 0.00236 seconds
Memory Before: 1,277.977 KB
Memory After: 1,278.898 KB
Time Before: 0.02490 seconds
Time After: 0.03254 seconds
Time Taken: 0.00764 seconds
Memory Before: 1,274.391 KB
Memory After: 2,355.609 KB
Memory Used: 1,081.219 KB
Time Before: 0.03983 seconds
Time After: 0.04002 seconds
Memory Before: 2,895.875 KB
Memory After: 2,896.492 KB
Time Before: 0.04312 seconds
Time After: 0.04433 seconds
Memory Before: 2,908.203 KB
Memory After: 2,908.063 KB
Time Before: 0.03895 seconds
Time After: 0.04455 seconds
Time Taken: 0.00560 seconds
Memory Before: 2,888.602 KB
Memory After: 3,021.133 KB
Memory Used: 132.531 KB
Time Before: 0.08298 seconds
Time After: 0.08314 seconds
Memory Before: 3,655.680 KB
Memory After: 3,656.195 KB
Time Before: 0.11820 seconds
Time After: 0.11945 seconds
Memory Before: 4,133.273 KB
Memory After: 4,133.867 KB
Time Before: 0.14393 seconds
Time After: 0.14411 seconds
Memory Before: 5,197.516 KB
Memory After: 5,325.859 KB
Time Before: 0.14820 seconds
Time After: 0.15032 seconds
Time Taken: 0.00212 seconds
Memory Before: 5,481.203 KB
Memory After: 5,610.805 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=23139', badlocation = 1 WHERE sessionhash = 'e60efe98bb3a97c417ccaae1b39ae601'
Time Before: 0.17213 seconds
Time After: 0.17241 seconds
Memory Before: 5,997.742 KB
Memory After: 5,997.969 KB
