Time Before: 0.00150 seconds
Time After: 0.00198 seconds
Time Before: 0.00205 seconds
Time After: 0.00254 seconds
Time Before: 0.00282 seconds
Time After: 0.00297 seconds
Time Before: 0.00380 seconds
Time After: 0.00664 seconds
Time Taken: 0.00284 seconds
Time Before: 0.00305 seconds
Time After: 0.01129 seconds
Time Taken: 0.00823 seconds
Time Before: 0.01323 seconds
Time After: 0.01366 seconds
Time Before: 0.01502 seconds
Time After: 0.01630 seconds
Time Before: 0.01256 seconds
Time After: 0.01648 seconds
Time Taken: 0.00392 seconds
Time Before: 0.02169 seconds
Time After: 0.02187 seconds
Time Before: 0.02420 seconds
Time After: 0.02551 seconds
Time Taken: 0.00132 seconds
Time Before: 0.02930 seconds
Time After: 0.02953 seconds
Time Before: 0.03179 seconds
Time After: 0.03326 seconds
UPDATE session SET lastactivity = 1773297400, location = '/forums/private.php?do=newpm&explain=1&u=23176', badlocation = 1 WHERE sessionhash = 'eaa8a3ac54cff5a66f956999e9bca4a9'
Time Before: 0.04772 seconds
Time After: 0.04811 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
