Time Before: 0.00899 seconds
Time After: 0.01083 seconds
Time Taken: 0.00184 seconds
Time Before: 0.01093 seconds
Time After: 0.01236 seconds
Time Before: 0.01258 seconds
Time After: 0.01271 seconds
Time Before: 0.01363 seconds
Time After: 0.01560 seconds
Time Taken: 0.00197 seconds
Time Before: 0.01276 seconds
Time After: 0.01900 seconds
Time Taken: 0.00624 seconds
Time Before: 0.02176 seconds
Time After: 0.02195 seconds
Time Before: 0.02491 seconds
Time After: 0.02615 seconds
Time Before: 0.02111 seconds
Time After: 0.02632 seconds
Time Taken: 0.00521 seconds
Time Before: 0.03960 seconds
Time After: 0.03972 seconds
Time Before: 0.13425 seconds
Time After: 0.13550 seconds
Time Before: 0.13997 seconds
Time After: 0.14017 seconds
Time Before: 0.14365 seconds
Time After: 0.14515 seconds
Time Taken: 0.00150 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=23180', badlocation = 1 WHERE sessionhash = '5dcfbb55b5add1e7cfb509ae0e835a95'
Time Before: 0.15814 seconds
Time After: 0.15842 seconds
Memory Before: 4,288.016 KB
Memory After: 4,288.242 KB
