Time Before: 0.00156 seconds
Time After: 0.00206 seconds
Time Before: 0.00213 seconds
Time After: 0.00254 seconds
Time Before: 0.00271 seconds
Time After: 0.00283 seconds
Time Before: 0.00348 seconds
Time After: 0.00581 seconds
Time Taken: 0.00233 seconds
Time Before: 0.00287 seconds
Time After: 0.01024 seconds
Time Taken: 0.00736 seconds
Time Before: 0.01285 seconds
Time After: 0.01326 seconds
Time Before: 0.01612 seconds
Time After: 0.01737 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.01217 seconds
Time After: 0.01764 seconds
Time Taken: 0.00548 seconds
Memory After: 2,261.719 KB
Time Before: 0.02340 seconds
Time After: 0.02352 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.02541 seconds
Time After: 0.02670 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
End call of global.php: 0.028620958328247
Time Before: 0.03003 seconds
Time After: 0.03024 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.03234 seconds
Time After: 0.03384 seconds
Time Taken: 0.00150 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=23272'
Time Before: 0.04730 seconds
Time After: 0.04757 seconds
Memory Before: 4,287.219 KB
Memory After: 4,287.461 KB
Page generated in 0.046311855316162 seconds with 9 queries, spending 0.0078999996185303 doing MySQL queries and 0.038411855697632 doing PHP things.
