Time Before: 0.00197 seconds
Time After: 0.00255 seconds
Time Taken: 0.00058 seconds
Time Before: 0.00264 seconds
Time After: 0.00339 seconds
Time Taken: 0.00075 seconds
Time Before: 0.00366 seconds
Time After: 0.00382 seconds
Time Before: 0.00452 seconds
Time After: 0.00718 seconds
Time Taken: 0.00265 seconds
Time Before: 0.00387 seconds
Time After: 0.01062 seconds
Time Taken: 0.00675 seconds
Time Before: 0.01266 seconds
Time After: 0.01307 seconds
Time Before: 0.01544 seconds
Time After: 0.01668 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.01210 seconds
Time After: 0.01685 seconds
Time Taken: 0.00475 seconds
Memory After: 2,261.836 KB
Time Before: 0.02206 seconds
Time After: 0.02222 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.02407 seconds
Time After: 0.02532 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
Time Before: 0.02828 seconds
Time After: 0.02843 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.03038 seconds
Time After: 0.03182 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
UPDATE session SET lastactivity = 1788975639, location = '/forums/private.php?do=newpm&explain=1&u=23305', badlocation = 1 WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.04429 seconds
Time After: 0.04459 seconds
Memory Before: 4,287.859 KB
Memory After: 4,288.070 KB
