Time Before: 0.00583 seconds
Time After: 0.00803 seconds
Time Taken: 0.00221 seconds
Time Before: 0.00812 seconds
Time After: 0.00870 seconds
Time Taken: 0.00058 seconds
Time Before: 0.00900 seconds
Time After: 0.00916 seconds
Time Before: 0.00982 seconds
Time After: 0.01230 seconds
Time Taken: 0.00248 seconds
Time Before: 0.00921 seconds
Time After: 0.01576 seconds
Time Taken: 0.00655 seconds
Time Before: 0.01980 seconds
Time After: 0.02030 seconds
Time Before: 0.02290 seconds
Time After: 0.02418 seconds
Time Before: 0.01888 seconds
Time After: 0.02450 seconds
Time Taken: 0.00562 seconds
Time Before: 0.03822 seconds
Time After: 0.03847 seconds
Time Before: 0.04425 seconds
Time After: 0.04553 seconds
End call of global.php: 0.047605991363525
Time Before: 0.04998 seconds
Time After: 0.05023 seconds
Time Before: 0.05262 seconds
Time After: 0.05416 seconds
Time Taken: 0.00153 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=23313', badlocation = 1
Time Before: 0.07146 seconds
Time After: 0.07170 seconds
Memory Before: 4,911.938 KB
Memory After: 4,912.164 KB
Page generated in 0.070467948913574 seconds with 9 queries, spending 0.0085446834564209 doing MySQL queries and 0.061923265457153 doing PHP things.
