Time Before: 0.00194 seconds
Time After: 0.00253 seconds
Time Taken: 0.00059 seconds
Time Before: 0.00264 seconds
Time After: 0.00306 seconds
Time Before: 0.00330 seconds
Time After: 0.00345 seconds
Time Before: 0.00446 seconds
Time After: 0.00706 seconds
Time Taken: 0.00260 seconds
Time Before: 0.00353 seconds
Time After: 0.01287 seconds
Time Taken: 0.00934 seconds
Time Before: 0.01562 seconds
Time After: 0.01604 seconds
Time Before: 0.01890 seconds
Time After: 0.02011 seconds
Time Before: 0.01483 seconds
Time After: 0.02038 seconds
Time Taken: 0.00555 seconds
Time Before: 0.02796 seconds
Time After: 0.02811 seconds
Time Before: 0.03033 seconds
Time After: 0.03156 seconds
End call of global.php: 0.033222198486328
Time Before: 0.03477 seconds
Time After: 0.03492 seconds
Time Before: 0.03790 seconds
Time After: 0.03931 seconds
SET lastactivity = 1785326348, location = '/forums/private.php?do=newpm&explain=1&u=23316'
Time Before: 0.05309 seconds
Time After: 0.05351 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
Page generated in 0.052163124084473 seconds with 9 queries, spending 0.0081706047058105 doing MySQL queries and 0.043992519378662 doing PHP things.
