Time Before: 0.01857 seconds
Time After: 0.02784 seconds
Time Taken: 0.00927 seconds
Time Before: 0.02796 seconds
Time After: 0.02838 seconds
Time Before: 0.02865 seconds
Time After: 0.02878 seconds
Time Before: 0.02956 seconds
Time After: 0.03194 seconds
Time Taken: 0.00237 seconds
Time Before: 0.02885 seconds
Time After: 0.03571 seconds
Time Taken: 0.00686 seconds
Time Before: 0.04445 seconds
Time After: 0.04486 seconds
Time Before: 0.04751 seconds
Time After: 0.04876 seconds
Time Before: 0.04372 seconds
Time After: 0.04909 seconds
Time Taken: 0.00537 seconds
Time Before: 0.08892 seconds
Time After: 0.08906 seconds
Time Before: 0.11074 seconds
Time After: 0.11200 seconds
Time Before: 0.11950 seconds
Time After: 0.11969 seconds
Time Before: 0.12208 seconds
Time After: 0.12394 seconds
Time Taken: 0.00186 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=23412', badlocation = 1 WHERE sessionhash = '19bddeacfb649beeea65b05d036d70bd'
Time Before: 0.14762 seconds
Time After: 0.14789 seconds
Memory Before: 4,288.836 KB
Memory After: 4,289.063 KB
