Time Before: 0.00196 seconds
Time After: 0.00266 seconds
Time Taken: 0.00070 seconds
Time Before: 0.00276 seconds
Time After: 0.00344 seconds
Time Taken: 0.00068 seconds
Time Before: 0.00366 seconds
Time After: 0.00382 seconds
Time Before: 0.00459 seconds
Time After: 0.00692 seconds
Time Taken: 0.00233 seconds
Time Before: 0.00387 seconds
Time After: 0.01119 seconds
Time Taken: 0.00732 seconds
Time Before: 0.01339 seconds
Time After: 0.01364 seconds
Time Before: 0.01635 seconds
Time After: 0.01762 seconds
Time Before: 0.01257 seconds
Time After: 0.01781 seconds
Time Taken: 0.00524 seconds
Time Before: 0.02475 seconds
Time After: 0.02489 seconds
Time Before: 0.02679 seconds
Time After: 0.02798 seconds
End call of global.php: 0.029635190963745
Time Before: 0.03076 seconds
Time After: 0.03090 seconds
Time Before: 0.03296 seconds
Time After: 0.03439 seconds
SET lastactivity = 1783435664, location = '/forums/private.php?do=newpm&explain=1&u=23417'
WHERE sessionhash = '785a5ccc852039ad054a2e3a39163c15'
Time Before: 0.04697 seconds
Time After: 0.04725 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
Page generated in 0.046027183532715 seconds with 9 queries, spending 0.0078647136688232 doing MySQL queries and 0.038162469863892 doing PHP things.
