Time Before: 0.02856 seconds
Time After: 0.03499 seconds
Time Taken: 0.00643 seconds
Memory Before: 1,246.203 KB
Memory After: 1,273.008 KB
Time Before: 0.03511 seconds
Time After: 0.03549 seconds
Memory Before: 1,272.969 KB
Memory After: 1,273.945 KB
Time Before: 0.03589 seconds
Time After: 0.03605 seconds
Memory Before: 1,274.586 KB
Memory After: 1,275.109 KB
Time Before: 0.03695 seconds
Time After: 0.03941 seconds
Time Taken: 0.00245 seconds
Memory Before: 1,277.977 KB
Memory After: 1,278.898 KB
Time Before: 0.03614 seconds
Time After: 0.04328 seconds
Time Taken: 0.00715 seconds
Memory Before: 1,274.391 KB
Memory After: 2,355.609 KB
Memory Used: 1,081.219 KB
Time Before: 0.05497 seconds
Time After: 0.05541 seconds
Memory Before: 2,895.875 KB
Memory After: 2,896.492 KB
Time Before: 0.05794 seconds
Time After: 0.05911 seconds
Time Taken: 0.00117 seconds
Memory Before: 2,908.320 KB
Memory After: 2,908.180 KB
Time Before: 0.05429 seconds
Time After: 0.05929 seconds
Time Taken: 0.00500 seconds
Memory Before: 2,888.602 KB
Memory After: 3,021.250 KB
Memory Used: 132.648 KB
Time Before: 0.10660 seconds
Time After: 0.10672 seconds
Memory Before: 3,655.805 KB
Memory After: 3,656.320 KB
Time Before: 0.17289 seconds
Time After: 0.17418 seconds
Memory Before: 4,133.352 KB
Memory After: 4,133.945 KB
Time Before: 0.20275 seconds
Time After: 0.20310 seconds
Memory Before: 5,197.547 KB
Memory After: 5,325.891 KB
Time Before: 0.20965 seconds
Time After: 0.21111 seconds
Memory Before: 5,481.227 KB
Memory After: 5,610.828 KB
UPDATE session SET lastactivity = 1772615398, location = '/forums/private.php?do=newpm&explain=1&u=23470' WHERE sessionhash = '600503b925d08d481e162d46884ab830'
Time Before: 0.23838 seconds
Time After: 0.23866 seconds
Memory Before: 5,997.766 KB
Memory After: 5,997.984 KB
