Time Before: 0.00984 seconds
Time After: 0.01677 seconds
Time Taken: 0.00693 seconds
Time Before: 0.01688 seconds
Time After: 0.01729 seconds
Time Before: 0.01783 seconds
Time After: 0.01797 seconds
Time Before: 0.01938 seconds
Time After: 0.02215 seconds
Time Taken: 0.00278 seconds
Time Before: 0.01804 seconds
Time After: 0.02657 seconds
Time Taken: 0.00853 seconds
Time Before: 0.03172 seconds
Time After: 0.03213 seconds
Time Before: 0.03526 seconds
Time After: 0.03646 seconds
Time Before: 0.03101 seconds
Time After: 0.03670 seconds
Time Taken: 0.00568 seconds
Time Before: 0.06612 seconds
Time After: 0.06626 seconds
Time Before: 0.07584 seconds
Time After: 0.07707 seconds
End call of global.php: 0.079478025436401
Time Before: 0.08511 seconds
Time After: 0.08530 seconds
Time Before: 0.08802 seconds
Time After: 0.08949 seconds
SET lastactivity = 1785311650, location = '/forums/private.php?do=newpm&explain=1&u=23542'
Time Before: 0.10251 seconds
Time After: 0.10282 seconds
Memory Before: 4,288.313 KB
Memory After: 4,288.539 KB
Page generated in 0.10160112380981 seconds with 9 queries, spending 0.0082650184631348 doing MySQL queries and 0.09333610534668 doing PHP things.
